hunter 40, yanmar 44. replace control cables. teleflex?
luvitt
Oct 30, 2008
297
na na na
i wanna repalace my control cables. the yanmar manual says to use "morse" control cables. can i use teleflex? same company right? whats the difference in cables, the ends? can i just measure the old ones, and buy the same length in teleflex?
thanks
G
Guest
Teleflex cables
I've used Teleflex brand shift and throttle cables on our boats and they work just fine with no match-up problems. Length is the most critical issue and to help obtain the right one, take the old one with you when you go shopping.
Terry Cox
Jun 9, 2008
1,860
- -- -Bayfield
I have never repalaced anything, but if you want to replace your cables you can use Teleflex because they purchased Morse and Morse is now Teleflex.
