Hunter 40.5 Hard Dodger
Nov 8, 2006
93
Beneteau 57 San Pedro, Ca
Alan,
I used Makrolon VR which is .030" thick. I have a sailrite sewing machine which worked OK sewing this material however the thread would fray and break about every 5 feet of stitching. I am sure that you could fiddle with the settings and needle to reduce breakage. I also had a sample of .060" Makrolon M5 which is very stiff and supposed to be more scratch resistant than the VR (although I could not tell from my samples). I was able to sew this as well. My project took just over 2 sheets so I went with the less expensive VR. The following is the quote I received from Interstate Plastics.
Hope this helps
The Marine 5 as the .060 gauge 50 x 110 inch panels. Price is $371.45/ea.
The Marine 5 as the .080 gauge 60 x 110 inch panels. Price is $520.20/ea.
The Makrolon VR as the .040 gauge 52 x 110 inch panels. Price is $66.00/ea.
The Makrolon AR2 as the .060 gauge 48” x 96” panels. Price is $190/ea.
Likes: SailormanDan
Hunter Catalina 400 PORT JEFERSON, NY
Frank
I am confused, did you use 30 0r 40 gauge and which thread did you use #69 or #92 or some other exotic
Alan J
Nov 8, 2006
93
Sorry Alan, I used .040" don't know why I have .030" stuck in my head. I used Tenera which I highly recommend. It hurts to pay for the spool but is well worth it in the long run. As an example, I made my sail cover using dark blue V92 thread and within 2 years I had light blue stitching (ugly) and it needed re-stitching in 6 years.
good luck with your project
Frank
Beneteau 323 Annapolis MD
I got some of the 138 thread from Sailrite, and it works okay in my machine. I'll be using it on the bimini and other Sunbrella.
