380 vs. 410
I checked out both the 380 and 410 (along with the Hunter 42CC, Beneteau 411, and 36CC and 40CC), prior to buying my 410, which I have lived aboard since September. I am very happy with my choice. It is certainly as roomy a 41 as you will find. Yes, it costs more, but I am not going to be buying another one, so I figured I might as well get the bigger boat and not worry about moving up again. The next one will be a trawler. Having gone from a Hunter 30 to the 410, however, was a giant step. I learned that the first time I tried to jibe in 22 knots of wind, without taking a turn around the winch. Won't do that again any time soon. I put a 3-bladed prop on instead of the standard 2-bladed prop. I like the added handling it provides in close quarters and, for as little as I race, I don't worry about the additional drag. The one option I would love to have is a bow thruster. Hopefully we can install one next year. In line with that thought, you will really appreciate the additional stopping power of the 3-bladded prop, when you need to pull into your slip a little faster than you would under normal conditions, when compensating for a wind that is continually trying to blow your bow off. I also have an inverter. Didn't get a genset, but for what I'm doing (mostly weekend stuff, since I still have to work for a living) its adequate. The bimini is nice when you're sitting in the hot sun having cocktails, but I prefer to take it off when I'm sailing. I haven't been able to get used to sailing without being able to see the sails. I also have an electric halyard winch...worth its weight in gold, unless you are 25 years old, 6'-8" and weigh 280 lbs. Good luck!
