Hunter 380 Inverter/Charger replacement
Aug 17, 2017
1
Hunter 380 Fort Pierce, Fl
My Freedom 20 that came with the boat only puts out 90 volts when inverting. I'm looking at 2000w replacements, but the space under the port settee is limited. Magnum and Go power pure sine inverter/chargers are two I've been looking at. They are bigger than the Freedom 20. The installation manuals for them call for more room for ventilation than is currently available under the settee. Perhaps I need to modify the space to make more room for ventilation and still keep it separate from the batteries.
What have 380 owners done to replace their Freedom 20s? Which units have you used?
Feb 17, 2013
53
Hunter 380 Port Clinton, Ohio
I installed a Victron Multi-Plus Compact 12/2000/80 inverter in my Hunter 380. Mounted it on the bulkhead wall in the forward closet. That keeps it away from the batteries. Great warranty on these units. I can start and run my AC unit on the hook with just a Honda portable generator. The Victron kicks in and adds the needed amps to start my AC unit.
Jun 1, 2009
1,876
Hunter 49 toronto
Go with Magnum
Excellent high quality unit.
Sep 2, 2017
4
Hunter 356 Apollo beach
If you would like to buy a Freedom 20 Charger Inverter, I have one to sell. Charges at 100 Amps, inverts at 2000 watts. I have the controler to it too. I'm in Tampa
The Book of Sail aka "The Book"
