Hunter 380 Freezer problems
May 17, 2014
136
hunter 380 Plano, TX
OK,, one other thing,,,,before I replace the blown controller, I need to ohm out the 4 pin grunert compressor. I can't find anywhere info on what my pin to pin readings should be. Anybody?
May 17, 2014
136
James, thanks for the manual,,,Will be calling AER tomorrow to see what the windings should ohm out
JamesG161
Feb 14, 2014
8,017
Hunter 430 Waveland, MS
You should also check the windings to ground. Sometimes called "Megging".
The compressor housing should be well grounded.
A winding bleed to ground will pop the fuse.
Jim...
