Hunter 38 cabin door latch removal.
Oct 24, 2019
47
Hunter 38 Baltimore
So the latch on the head door jammed. I took all the screws out but the little "L" shaped lock mechanism will not come out. Before I take the grinder to it has Anyone ever taken one of these apart ? Has anyone found a replacement latch for reasonable money ? I know they have them here in the store for $200 but like so many other boat things it sure seams like a $39 part. Thanks guys
Sep 22, 2009
134
Hunter 36 Seattle, WA
I have taken two apart and replaced them. The L piece may need assistance from a hammer, but it does come out. The replacement IS pricey, but locks are that way. HinterOwners.com has them. I believe Defender does as well.
Oct 24, 2019
47
Hunter 38 Baltimore
thanks Stuart. I did give it a few taps with the hammer as hard as I dared. The doors are so thin in that spot I was afraid to break the door. I'll take my skirt off and give it whack next time I'm down there. And I guess I'll buck up and pay the piper for a latch.
Beneteau 323 Annapolis MD
.... I did give it a few taps with the hammer as hard as I dared. The doors are so thin in that spot I was afraid to break the door. I'll take my skirt off and give it whack next time I'm down there. And I guess I'll buck up and pay the piper for a latch.
A Benny friend got locked in the head when the lock failed to open. On the boat alone, but waited for a passer-by to come aboard to unlock from the outside. She could have taken the lock off the door, for the want of a phillips screwdriver. After that, I kept a screwdriver on the head shelf.
Oct 24, 2019
47
Hunter 38 Baltimore
Now that's funny on one hand and scary on the other. Out sailing by yourself you'd be breaking the door down. On our boat a phillips would not do the trick. A flat blade to jamb there and pry the door open would get you out. I think I'll leave one in there.
Apr 11, 2010
976
Hunter 38 Whitehall MI
since the 38 has two doors to the head it’s unlikely that you would need a screwdriver for emergency exit.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I had a similar problem with the rear berth door lock sticking on my 2007 H-36 but took it
apart lubed it but because door is left open 24/7 and doesn’t get used so can get stuck again.
$$$$ crazy way over priced try taking a part and put lub keep from sticking.
Nick
Oct 24, 2019
47
Hunter 38 Baltimore
From what I can see when I took the cover off the latch housing is broken. I tried lubing it but no luck then I tried to remove it and exchange it with a latch from one of the other doors that is not used as much but I couldn't get either latch out. That's what prompted this email since I couldn't get either latch apart and didn't want to break the good one. Even though I knew it was a long shot I removed another door to exchange with the head door as that is the more important one to have latch but the hinges were not in exact same spot and I wasn't about to start down that road. I did some looking and every boat door latch I see is $100 and up so I'm just going to bite the bullet. I was hoping someone might have had a source for a cheaper one.
Dec 19, 2006
5,832
What year Hunter 38 do you have and my 2007 H-36 latch was not too much trouble taking apart, where are you located.
Nick
Oct 24, 2019
47
Hunter 38 Baltimore
Rock Hall Md. 2005. I have the store here looking for the latch for me. I may wait till I get the new one to see how it's put together or I'll just drill the old one out till it falls apart
