Straight and Steady
Bud, After 6 years of passable but not great ST4000 performance, I installed a rudder reference transducer on my Hunter 30 this spring. It made a new machine out of it. The boat now tracks much better under sail and there is not as much drive activity which translates into less wear and tear and less electricity. If I knew then what I know now the rudder reference would have gone on with the initial installation. If your rudder set up is similar to mine (88 model) then the unit just mounts in the well next to the quadrant and attaches to the quadrant with the supplied hardware and little homemade aluminum angle bracket. Run the cable to the autopilot control unit.
