Hunter 36 Vision technical info
42
Hunter 35.5 Adger, AL
Does anyone have the wiring, and plumbing layouts for the Vision 36?
I've looked around, and haven't really found any (yes I looked at Ayesail)
It's not crucially important, but I would like to have the information for when I start looking at possible candidates for purchase.
James L
Dec 2, 1999
15,184
James:
I may have them in my original documentation. I will try to remember to bring the manual home this weekend if there is anything worth sharing.
What are you specifically looking for?
Oct 23, 2012
42
James:
Steve,
I'm just really looking for locations for wiring and plumbing. It will help with my initial inspections of any Visions I do. I'm quite thorough when I do my initial inspection, and like to have an idea of where everything is to reduce the chaos of moving cabin sole and such.
I am thorough, but also try to be respective of the current owner, and only move the pieces that I feel need to be moved. It also saves a bunch of time.
I would greatly appreciate any information you could relay. A scan of the wiring and plumbing layout would be the most helpful.
James L.
Dec 2, 1999
15,184
James:
I remembered to bring the manual home. There are about 16 pages that I can scan. I will post them on the website. It should be done by this weekend.
Steve
Oct 23, 2012
42
James:
Steve
Wow, thanks Steve......
It will help a lot when I start the pre-purchase inspection part.
Got in contact with the people who make the Dutchman flaking system today. They said it would be no problem to put their system on. I was worried about the size of the sail, and also it's tendency to spill air.
Now, to actually start looking at Visions. I do have a fall back plan (35.5) but really want the Vision.
James L
-na -NA Anywhere USA
Steve Dion;
Thank you in advance for doing that for your fellow sailor. If no one else will thank you, I will. Take care my friend and again thank you for your support in these forums.
crazy dave condon
