Hunter 356 Headliner Removal
Jun 21, 2016
27
Hunter 356 Annapolis, MD
Has anyone successfully removed and reinstalled the vinyl headliner on a 2003 or 2004 Hunter 356? I need to replace the VHF cable that is above the headliner and would like to accomplish this without damaging the headliner. I have looked at the various threads on the Forum that explain a method using a putty knife to pry the vinyl loose from a groove, but the headliner on my boat does not have same configuration at the edges as is shown in the most detailed thread.
Jun 15, 2012
717
BAVARIA C57 Greenport, NY
I suggest that you post some detailed pictures of your headliner. I didn't believe the putty knife instructions on mine when I first tried to remove the headliner, but after some guidance from Uncledom it worked.
Jun 21, 2016
27
Thanks -- that's a good idea. I will post photos this weekend.
I'm still finding little beige buttons and I sold the boat years ago.
Mar 20, 2004
1,753
do post some pictures - I've never seen a 356 with a different headliner...
If you use a putty knife be very careful - the sharp corners can cut the headliner. I use an automotive headliner tool, looks like a putty knife but the corners are rounded.
Jun 15, 2012
717
I modified a s/s putty knife by filing the sharp edges round. I also use a automotive interior tool kit like this on from Harbor Freight,
Trim And Molding Tool Set 5 Pc.
Once I open up the moulding, I grab and pull out the vinyl with a
Mini Pick and Hook Set also from HF.
Jun 21, 2016
27
Aha. Thank you. It sounds like there are two steps -- opening up the moulding and then pulling the vinyl out. Is the putty knife with rounded edges used only for opening the moulding? In the earlier thread on this, it appeared the knife was used to open a c-shaped channel to release the vinyl. For opening the moulding, do you insert the knife along the outboard or inboard edge of the moulding?
Mar 20, 2004
1,753
insert the knife towards the outer edge to spread the channel, then pull the headliner carefully out. use the knife to push the headliner back in when you're done
Jun 21, 2016
27
the instructions in the original thread say to start at a corner. I cannot find a way to get knife under the edge of the headliner in these corners, where the channel holding the headliner is either not there or not visible.
1,753
yes - I sometimes use a small pair of needlenose pliers to start the headliner out
Dec 22, 2012
95
Hunter 27-3 103 Gables By The Sea
When the mast was down, took advantage to run new antenna and cable. Used RG8X which is about 1/4" instead of the original antenna wire from the factory which was about 2 times the thickness. In my boat there was a separate wire chase which was used to run the wires for the wind instrument and the masthead anchor/masthead light. The original large antenna wire was not run in this chase. There was no messenger line in the chase so the plan was to pull out the wires pulling a messenger to then pull back the same wires plus the new antenna wire. At first the wires would not budge but a generous heavy application of silicone spray shot in the chase managed to get things moving easily. This of course means running a new wire up the mast which is probably not a bad idea; replace the antenna also. By the way just abandon the original cable, cut off the ends. Run the new cable as a home run from the antenna to the radio unless your mast comes down yearly. This will most likely be easier, faster and cheaper than removing the overhead liner and also the side ABS plastic side liner behind the window frames. Not to mention that you will most likely damage the Whisperwall vinyl and have to replace it all to match. Also note here are the overhead grab rails to deal with. This vinyl is now 14 years old and delicate. As an example I put some blue masking tape on the vinyl and when it was removed it took some of the vinyl with it. Good luck.
Dec 22, 2012
95
Forgot to mention interior lights to remove also. The junction teak cover plate just drops down after you remove the screws.
