Hi all,
I’m wondering if someone can point me in the right direction with respect to this electrical issue we are having?
When I plug our Hunter 356 (2002) into the shore power connection on the hard it instantly trips our panel. Our boat is in the original OEM spec with just the two battery standard configuration. Everything is in the off position when I switch the panel on and has absolutely no load whatsoever.
When the boat is in the water plugged into the shore power pedestal on the dock everything works perfectly normal. This only started happening when my yard upgrade the outdoor outlets to new GFI’s a few seasons back, others in the yard seem to have no issue.
I’m using the standard pigtail connection to a high-quality extension cord. I’ve ruled out extension cords being the issue, as well as the pigtail as I’ve tried multiple different gauges of extension cords different pigtail fittings to ensure I eliminated if any of those had a weak point.
Any thoughts?
Best regards,
Any thoughts?
Best regards,
