I found Invoice from purchasing Teleflex Morse 33C Red Jacket (301947) cables in 2004. I replaced BOTH the Throttle and Tranny cables at the suggestion of Bay Breeze Yacht Charter's chief mechanic, even though only one was binding... and I'm glad I did. The extra $50 for second cable was well worth the peace of mind and not having to do that job again for many, many years. The cables were 14ft and 16ft and i'm not near my boat to tell you which was which, but one quick look at your engine and you'll know which has to be longer. NOTE TO REMEMBER: There is a "Cable Tension Screw" on the Throttle Cable located at the top of Edson Pedestal. Once you get the new cable installed, you'll probably notice that when you push throttle ahead to give gas (engine OFF) and release, the throttle handle comes right back at you under its own power. The new cable is so slippery (inside) that you need to crank the "Cable Tension Screw" down to induce some friction to hold Throttle in desired position. No Tension screw on Tranny cable. And, depending on what you have mounted on the top of your Edson Pedestal, it is a JOB to get back to that Tension Screw again, so get it where you want it the first time. My suggestion: Buy both cables. Good luck.
Richard Strohkirch
s/v "Lake Affect"
