Hunter 340 Standing Rigging replacement cost estimate
doccjt
Feb 10, 2022
4
hunter 340 panama city
How much should I expect to pay for replacing the standing rigging on a Hunter 340?
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Will you buy it and install it yourself?
My guess is about $1500, based on my spreadsheet for my Tartan 3800, buying the rigging from Rigging Only in Fairhaven, MA. Highly recommended, you can do a mail swap of your old rigging for new.
Joe
Jun 1, 2004
8,249
Replacing the standing rigging can have some options. You can just replace the wire and keep the turnbuckles, for instance. That'll save you $500 or so... You can do it yourself. Go to an online rigging site. Order the wire, purchase the fittings, cut the wire and install the fittings yourself. That can order the wires precut with sweged on fittings by the supplier (that's my choice) then get a friend to haul you up the mast and save quite a bit on labor. OR.... and this may be best for you... hire a local (independent) rigger... to give you and estimate and let him guide you in replacing the various fittings. The reason I recommend "local, independent" riggers is that large rigging companies largely more costly and less willing to work with you to help your budget. Many of these types have relationships with large yacht clubs and wealthy racers, so they pattern their services to the big bucks type of yacht owner... Therefore I recommend you get online or solicit your marina management for their recommendations...at least start getting some of your own estimates. Finally, DIY makes it possible to replace the rigging by increments, as the budget and time allows. Good luck.
Dec 25, 2000
5,948
As a key part of this project, be sure to perform a visual inspection of your chain plate condition where it attaches to the hull.
Sep 24, 2018
3,768
Catalina 30 MKIII Chicago
Another advantage to using a local rigger is that boats aren't always built symmetrical. One of my shrouds is an inch longer than the other. The local rigger suggested making both of them the same length. One didn't fit. Now he's redoing them at his expense :oops:
