Hunter 340 Salon Table
Nan340
Sep 25, 2012
5
Hunter 340 Midland
We own a 1999 Hunter 340 and have not needed to lower the salon table until now. Can someone provide instructions on how to do it correctly? I checked our Owner's Manual and I cannot find anything referring to this. I need this imformation urgently because I have grandchildren coming on board for the first time this week. Thank you in advance for any assistance you can provide
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
Under the front of the table is a T handle that you loosen to raise or lower or rotate the table around the compression post.
If that T is loose and the table won't move, do you see a 1/4 inch diameter cord running from the table up to a block in the compression post. Try pulling that to move a heavy counterweight inside the compression post. Let us know if you still have a problem.
