Source of smell
Stagnant raw water can definitely be a source of smell, and I have a tee above my seawater intake seacock which doubles as my sink drain outlet so I canflush with fresh water from the sink and force seawater out of the intake line. However, as I discovered, "head" odor can definitely come from the tank area itself. Like the previous post, I also found the plywood under the old tank to be wet, prompting replacement of the wood base, a thorough wipe of all surfaces with diluted Clorox, AND installing a new (thicker-walled) tank. Old tanks and fittings can indeed be the culprit! (While at it, as I mentioned before, I replaced the hand pump and the hoses as well, why not while you're in there...) As Peggie pointed out, follow you nose for the major source of odor, although all the other steps mentioned will certainly help in maintaining an odor-free environment.Two years later I am still odor-free.
