Hunter 34 Reefing and; Lines led to Cockpit?
Aug 20, 2025
6
Hunter 34 Penetanguishine
Looking for information regarding the original reefing system, (or something better) for the Hunter 34
I have a 1985 Hunter 34 with no reefing system except the hooks at the fore end of the boom.
I understand that the boats originally had a reefing system.
Also;
The boat has provision for four lines to the cockpit, but only the boom vang is currently led to the cockpit.
What lines originally came to the cockpit?
Can we assume that the provision for four lines leading to the cockpit are from the boom? If so I would guess one outhaul line and two reef lines.
The hooks suggest it was designed for slab reefing and not for "Single line reefing" (Defined as using one line to bring both the tack and leach down to the boom). But you can re-design the system to fit your intended use - single line, two lines, reefing from the helmet from the front of the cockpit, single handed, crewed etc.
I had a H 356 2002 and whatever I had on that would not translate to a 1985 H34.
H34 owners will chime in with details. You can search the net to see a large variety of ways to do reef. Try key words "Slab reefing, Mainsail"
Aug 20, 2025
6
The provision for the lines is from the area just aft of the mast.
There are also four sheaves at the base of the mast; coming from within the mast, but no lines coming through.
Thanks;
They still could be for reef lines but they could also be for halyards. Do your halyards run to th cockpit or do you tie them off at the mast?
Aug 20, 2025
6
Currently, the halyards come out of the mast a few feet up, and there is a winch plus a cleat on either side of the mast.
Looking at a few later Hunters, there is a folding step where my winches are; the halyards come out of the mast, go to a turning block, and back to the cockpit.
Nov 6, 2006
10,165
Hey, Brian.. Here is what I have on my '85 model H-34. The previous owner raced the boat and had the jib halyards, port and starboard, exit the mast a couple of feet up and go down to a pair of added turning blocks bolted to the mast base. The port side lower mast base has the spinnaker halyard which enters the mast a few feet from the top. The starboard side mast base has the spinnaker topping lift and the main halyard. The reef lines are the lines aft of the mast that go down to the blocks on the pad eyes on port and starboard. These are all led aft to the cabin top by the winches. The reef lines go to a cleat and the others go to rope clutches. I have no winches on the mast.
Aug 20, 2025
6
Thanks for the info.
I would appreciate some sort of diagram of how the reef system/lines work or are led.
The boom is a Harken unit; not sure if it is original.
There are no blocks etc on the boom; nothing apparently for a reefing system.
Nov 6, 2006
10,165
On my boom, The reefing lines go from the cabin roof cleat through the "tunnel" to the deck organizer. From there, to the small blocks on the eye just behind the mast, up to the sheave on the forward end of the boom that directs the line inside the boom to the sheave on the aft end of the boom. From there up to the reef cringle (grommet) on the sail then back down vertically where it is tied around the boom. There are no external sheaves on the boom. I am pretty sure that my boom fittings aren't Harken castings.
This is the forward end of the boom; the small line exiting on top is the reef line. There is a cam cleat at the sheave but I leave that open. The bottom line is the outhaul; it has a 2:1 purchase on the outhaul which exits the aft end of the boom.
10,165
To reef the main, the main halyard is slacked to hook the reef tack onto the reef hook at the front of the boom; someone has to go to the mast to do that. . Next the appropriate reef line is pulled to bring the reef point down to the boom. The reef line is cleated off, then the main halyard is tightened using the cabin top winch. Hope that helps
EDIT: Here is a picture that shows the end of the reef line tied to the boom. Its kind of a janky set-up but is commonly done that way. Some folks have a little eye screwed to the boom and the line is tied to the eye..
6
Ah; I will have to look closer to see if those sheaves are on the boom.
Presently, the only line in the boom is the outhaul.
There were the remains of an eye on the port side of the boom.
It appears to have been chrome plated zinc, which corroded away;
The (machine) screws were stainless, and subjected the aluminium boom to galvanic corrosion.
Took me some hours to get the remains of the two screws out; impact screwdriver, other tools and persistence!
Likes: kloudie1
Dec 14, 2003
1,446
Kloudie, like me, has the original Kenyon boom. If you have it too, you'll see the 3 sheaves for the 2 reefing lines and for the outhaul at both ends. For your info, the attached will show you how I rigged mine. Like Kloudie I have no winch on the mast. I installed sheaves near the bottom of the mast, doubled-up the deck organizers and added cam cleats in front of the winches near the companion way, so that I now have everything except the spinnaker halyard coming to the cockpit. Look at the the pictures. Hope this helps.
Likes: kloudie1
Aug 20, 2025
6
Thanks for the ideas and the pictures;
Some of the described hardware is on the boat, but not in use; some appears to be missing.
This particular boat has provision for two lines through the tunnel on either side, with two stoppers either side, and a winch either side.
Only one line in use; the boom vang.
More suggestions gratefully received!
Hunter 34 Herrington South, MD
I upgraded my H34 also. Had to add a double set of deck organizer sheaves for the lines. My 84 H34 apparently has an aluminum place in the deck that can be drilled and tapped for newer deck organizers. Not a big deal to buy a tap and drill to install a new deck organizer. If it is windy enough to reef the main, reefing from the cockpit is preferable.
