Hunter 34- Opening Ports Made by Gray Enterprises
Jerry Keto
Opening ports made by gray enterprises (1983) have white knobs for dogging . I have several of these knobs that are cracked and do not hold up well to epoxy repair. Has anyone found like and kind replacement knobs for these ports? Also does anyone know of replacement screen frames. Please respond to ketoj@aol.com or ketoja@nu.com. Thanx
A
Andy
Try JSI
I think Grey was bought out by Bomar. JSI carries a full line of Grey/Bomar opening ports and parts. http://www.sailnet.com/store/
Mac Lindsay
Opening ports
Jerry; Contact Pompanette Inc PO Box W Charlestown NH, 03603 Att Jennifer Porter 603-826-5791 Fax 603-826-4125 I replaced all the opening ports and gaskets on my 1984 H31 which are gray marine. Pompanette/Bomar will give you the part numbers you need and you probably may order direct from them. Being in Canada, I simply took the part numbers to my marine store and they were able to order them for me. Hope this helps, Mac Lindsay S.V. Kitkatla
Roger Mummah
Thrift Mariner had gray Ports
The Thrifty Mariner in Fort Lauderdale, Florida sells Gray ports. They may also have parts. Try www.thriftmariner.com Good Luck Roger Mummah s/v Endless Summer H31 #58
Derek Rowell
Compatible knobs
I replaced the knobs several years ago with Beckson cam-knobs from Defender. They come(came) in two thread sizes - one for Beckson ports, and a larger one that fits the Gray ports. They have worked well - the adavantage is that you can simply flip the levers to open/close. Derek
