I have a Hunter 34 and I am upgrading the instruments (Data Marine gear is dead) and I am trying to locate the depth transponder. I found the speed transponder, but for the life of me, cannot find the depth one. Can anyone let me know where to find it? Also, has anyone installed an in-hull transponder on a Hunter 34? The thru-hull speed transponder is smaller then the modern ones built by Airmar. I assume the depth one is of the same size (if I can find it). The easiest thing may be to install an in-hull one next to the front bilge pump. I believe the fiberglass is solid there. Any suggestions or tips would be appreciated?
