Well I found this little gem while cleaning and doing other refit related items... What does everyone make of this? I found it behind the stove and oven area when I removed them to take them home for cleaning. I have sounded the hull with a plastic hammer in the same area on the outside and all sounds normal and there does not appear to be impact damage, but the boat was also painted topsides by the previous owner, so for all I know he sanded and faired external cracks painted it and didn't actually repair any damage.
Would you guys do anything to affect repairs, sail it and monitor it, or leave it alone? Is this just the inner liner that is cracking, or possibly just gelcoat cracking from oil canning? Obviously someone has painted resin or epoxy over the horizontal crack at some point, but no idea who and when that was. I'm at least the third owner of this boat. On the hard right now so its the best time for repairs if I'm going to do them. If I should repair, how should I go about it, just grind/sand back until no more delam, feather it in, and epoxy/biaxial cloth along the cracked area in a 12:1 ratio?
