Aloha everyone,
I bought a 1985 Hunter 34 in September of 2019 and just noticed a lot of corrosion on the aft keel bolt. Previously it was not corroded at all and looked great. I thought it was coming from the stuffing box, as it looked like there was evidence of a leak running down below the motor into the aft keel area, but I cleaned the bolt & plate recently and noticed that it's salty again, there also looks to be bubbles of salt seeping in from the side/bottom of the backing plate.
I attached some pictures for reference.
Has anyone seen this before, is it possible to have water seep in from the bottom of the backing plates? Also, can this be fixed with a new backing plate and nut provided the bolt isn't corroded to the plate, can the bolt be replaced if need be?
Thanks,
Chris
Thanks,
Chris
