Dave
The hunter 336 across the dock from me was overheating slightly this summer. Cleaned out the heat exchanger, replaced the impeller, checked the thru hull to make sure adequate water flow was available. All to no avail. Could the problem be in the water pump for the anti freeze mixture (internal cooling system)?Pete is worried that if he ever leaves the dock the engine will over heat.Any advice will be most helpfulThanks,Dave
