Jim Logan
Do any of you h33 owners have any experience with leaks around either the rudder shaft or keel bolts on your boat? I'm going to pull the boat for a bottom job, and replace the stuffing box with a dripless shaft seal, But since I am tired of the water in the bilge, I want to fix all the problems at once. How do I tell whether I have a keel bolt leak versus a rudder shaft leak - both areas are damp, but I can't see any drips or running water, yet my bilge pump cycles about once every 2 hours when sailing, and there is usually some (not much) water in the bilge when at dock. Even when I stop the drips totally on the shaft stuffing box, I still get the water when sailing. Any ideas?
