Another Option
If you like the Cherubini style boat, the easiest way to get 4' draft is buy the shoal version H33. I think it would be cheaper to find a new boat than to change the keel on your own. H37C also has a shoal version AND gives you the excuse to move up. Option 2 is to buy a 2-3" thick piece of iron and have it cut in a "neato" wing shape with smoothed edges. Then cut the appropriate amount of keel off the bottom and bolt/weld the wing plate on it. The wing width could be up to about 50% (my design is 42%) of beam width, as long as the keel, and would allow you to go on the hard in low tide much like the Scheel Keel. On the other hand, we have seen threads here concerning the structural capability of a Hunter to rest on it's keel. I am afraid to ask an engineer what they think of this plan as I am certain they would say I am completely nuts. What do all of you think? (About the plan that is; comments regarding my sanity are not invited.)I haven't worked out the formula yet, but I think the extra 1,000 lbs. and the foil of the wing will overcome the added wetted surface area and should allow me to carry more sail above 18 knots. Then again, she'd be a little slower in the light air. If one ever ran aground in soft mud with this plan, it would be nearly impossible to free the vessel any direction but backwards. But since I haven't run aground in well over a week, this is probably not a problem either.
