Hunter 320 v. 326
476
- - long beach, CA
Want to downsize from my Beneteau OC400 to a Hunter thirty-something. Are there any significant differences between the 320 and 326? I want the B&R fractional rig.
Rick D
Jun 14, 2008
7,206
Go To Hunterowners.com and....
...then to the boats tab. From there you can pull up the 320 and 326. In fact, if you do it in different windows, you can see them side by side as I just did. Anyhow, the specs are the same for both but for a 200 pound displacement increase on the 326. Tankage, power, sail area, et al are the same. There should be owner reviews there, but what you need is for an owner to tell you what the significant differences are and I'm sure someone will weigh in with it. BTW, a 32' boat is a real nice size, huh? Rick D.
G
Gary
The 320
Hi Larry,
I would like to know too! I have a 2001 H320, bought used. All I know is that the windows in the galley are smaller on a H326. I do know that the H326 has a new interior that was supposedly built separately and then dropped in (IIRC) and has a laquer finish instead of the older oiled finish. Als,o I have noticed that the rubrail is different, the H326 has a stainless steel insert. Oh, I also noticed the charttable area is slightly different and the tankage metering is different.
BUT, all these changes except the windows(well.. ports?) are on my H320 since as a 2001, its one of the last, I believe.
Gary
Emeryville, CA
