Hunter 320 Shrouds tensions
Mity
Aug 25, 2011
53
Bénéteau Océanis 343 2 Montréal, Canada
Hi, I just bought a Hunter 320 and I would like to know if someone would know the recommended tensions for the shrouds. I am using a Loos PT2-pro Rig tension. In the Hunter manual there is no indication for this :confused:.
Thanks in advance!
Michel
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
Tensions are generally based on wire size. If you rarely sail in strong winds, 10% breaking strength is a decent place to start. If it is not in the manual, contact Hunter for a definitive answer. Most 320's are in-mast furling (right?) so there will probably be no mast bend to consider.
Mity
Aug 25, 2011
53
Thanks for the reply Clark. I also sent an email to then and they just replied back with the recommandation of 20% and a sheet as reference.
Michel
Oct 29, 2005
2,362
You could also check Brian Toss books and video. I understand typically tension is set for about 15% breaking strength of the wire.
