Hunter 32 vision 1989
Ed D
Nov 22, 2009
39
Hunter Vision 32 Jacksonville Florida
Hi
Has anybody installed an electric toilet connected to the fresh water system on a Hunter 32 Vision .Second question does anybody know the Gallons per minute flow on a hunter 323 Vision with 3/8 Id tubing system
Sep 3, 2012
195
Hunter 285 Grand Rivers Ky
Seems to me that If you don't want to use raw water from outside the boat, then I think you are better off installing a second water tank for flushing and keeping your clean water system clean. No matter how many one way valves you install, seems like bacteria always manages to contaminate the water system when they have any connection. Probably because of the pitching and rolling of the boat and the lack of a fresh tank like in your home. How big is your holding tank? install a secondary water tank that is about 90% of that size. Keep a connection to outside water through a "Y" valve incase you can't get water.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
There are lots of posts on the shared forums about connecting the sink drain with a "Y" to the raw water feed. This allows you to run fresh water into the head sink and use that for the last flush of the day. It's sanitary and uses way less water.
Ken
