Hunter 31
Jun 12, 2013
213
Hunter 40 back creek
I have a hunter 31 with a tall rig the mast is 46.4 and I was wondering if anyone would have the forestry specs eye to eye length for this boat with a tall rig?
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
Not familiar with the term "tall rig" on a 1981 H31. Heard of this on similar vintage Catalina 30's. Look in the owner resources of this forum. There is a H31 and H31' 83-87 with a similar mast height. May be able to determine your measurements from there.
Jun 12, 2013
213
What's going on is I have measurements I received from a forum participant for my h 34 that I needed a mast for and I found a mast that I watched a crew take off a hunter 31 1981. When I did the measurements of that physical h 31 mast it was identical to my other h 34 mast I had alongside of it in the work yard except for the aft stay legs we found the h 34 tall rig were approx 2 ft shirter than the h 34. . All the other rigging seems identical to my H 34. I'm just having a hard time wrapping my brain around the fact that this is matching up so well. The problem here is that I should have been more thorough and measured all the rigging on my h 34 while it was on the ground but I missed the boat on that one! This is why I want to make sure the fore stay from this is correct before I step it!
Jun 12, 2013
213
Hi, I know that's an option but I have been advised that using the quick connect fittings on old wire is dangerous ?
