Jim
I know that many of you have had the mast compression post problem. But i am considering buying a 1985 hunter 31 that has the problem and fixing it myself. The overhead is deformed. The structural beam does not appear crushed. The teak on the post is bowed (compressed too much). Where can i get the original dimensions for the compression post? How difficult is it to de-step and re-step the mast. Also water is leaking in and running out the port and stbd halogen light locations at the base of the overhead beam, i assume this is from the base of the mast leaking. Any inputs would be greatly appreciated.
