Hunter 30T Wisker Pole attachment
Jul 7, 2010
35
Hunter 30T Grand Lake, OK
On my Hunter 30T, I have a wisker pole that came with the boat attached to the foredeck. However upon inspection there is no ring, track or attachment point that I see on the front of the mast to use such an item when sailing downwind. Anyone have any ideas? Different point of attachment? If not I need to look at adding one to increase our down wind sailing options.
Thanks
David
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
@fbcoache a couple of pictures is worth thousands of words, but, it sounds as if the whisker pole is a deck fixture and not quite usable, without a ring to clip it to the mast.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
My 30T has one about knee high. The rectangular base of it is curved to conform to the mast. It's in my avatar if you can enlarge it enough. I don't have the full size pic handy
Beneteau 323 Annapolis MD
If you have one particular sail you will be using, I suggest attaching the pole to the clew, extend the pole so the sail is all the way out, make the pole level/make the pole perpendicular to the mast, mark the mast for the ring.
Jul 7, 2010
35
As you might imagine I was shocked to see it on the foredeck and then when I actually tried to use it there was not an attachment point. I purchased the boat used and the 2 previous owners never sailed wing on wing or with a large down wind sail. I found it odd to have this piece of equipment on deck but not be used.
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
In lieu of a fixed point on the mast suggest adding a “T” track of about 3 to 4 ft in length along with an adjustable car/ring for horizontal adjustments on your pole. Check boater resale shops for track and car. Often times a lot cheaper than buying new metal. I know. I just donated these to a resale shop. If going the track mounted route then use tef gel or similar for SS bolts on aluminum mast
Jul 7, 2010
35
I was looking to go the track route so I would use it with different sails as well as a adjustable attachment point for other items as well. Thanks for the idea about a resale shop would not have thought of that.
Jul 7, 2004
8,542
I wish mine was easily detachable. My jib sheets get snagged sometimes when we tack. I'll probably come up with some way to wrap it so the sheets glide over it. It happens when we get too sloppy and pull the sail in too soon.
Jan 29, 2010
15
Hunter 30T Solent, England
Hi David,
I've added a 3 metre track to the front of the mast on our 30T over here in the UK. (See picture) the Whisker pole stores neatly on the front side of the mast and is quick to deploy. Simply unclip the lower end and drop the top end down the track on the car. The ring can be locked off at any height on the track to suit.
Cheers
Shaun.
35
Thanks, I like the idea of being stored on the mast. I'll have to investigate that option more.
Dan_Y
Oct 13, 2008
524
Hunter 36 Hampton
Our '91 Hunter 30 T had an Isomat NG31 mast with built-in spinnaker pole/whisker pole track. It was sweet and part of the mast extrusion. You can get something like an NG-50A car for it and kits (bottom of NG-50A car page) to raise and lower the mast end of the whisker pole as well as store it. To store it, you hauled the mast end up the mast track and hooked the sail end into a fixed ring at the bottom of the pole. Worked like a charm. I can dig up a photo if you are interested.
Dan
