This is doable.
There is always a way on a boat. Sometimes, we need to be creative
Completely agree.
it's worth trying to pull it through to see if you can pull a new one using the old cable
Again, completely agree.
In my case just this past winter layover (all winter long) I did what you are going to do, run a new coax cable from the mast (inside the cabin) to the electric panel at the navigation station. To relocate my VHF from the pedestal to inside the cabin.
At one point I entertained the thought of cutting an access hole in the headliner as well. That won’t be as easy as it may sound. On my 340 the headliner was all of 1/4” to better than 3/8” thick in spots.
Please do not let this sway you or scare you. It takes time and patience.
If you look in the forum archives under “What grade VHF Antenna Coaxial Cable was used in a 2000 Hunter 340” it will outline my process to completion.
I found a Flat Snake will find its way through the existing wires and cables in the headliner. Better than cable pullers.
By all means, Try to pull a new messenger line through using the coax you have, I could not get enough leverage on the cable to do it but you may have better results. Worth a try.
And get a friend to help. The distance between both points is too far for you pull alone with great effectiveness.
As I said, don’t let this sway you away from the project, I hope it helps clear it up a little.
I know there is plenty of space in the headliner for another cable in there. Once you have a messenger wire in place you will be able to pull a new cable through.
Be cautious if the thickness of the cable you choose.
Read the posting I highlighted, it will answer more questions for you.
