Scott
HelloI have a 1977 Hunter 30. Mast appears to have sunk into the deck approx 1/4 to 1/2 inch. I was wondering if this mast is keel or deck steped ?. There is a corroded steel I-Beam attached to the keel under the teak surround extending below the mast, on top of the I-Beam is a rotten piece of 1/2" wood that is obviously compressed from the rot. I would like to disassemble this teak structure to see what is causing the problem (or is the rotted piece of wood on top of the I-Beam causing the problem). Any answers / suggestions greatly appreaciated.ThanksSCA
