HUNTER 30 74-83
TONY A
Mar 7, 2005
30
Hunter 30_74-83 JACKSON, NJ
QUESTION: What alcohol stove came as standard equipment in the Hunter 30 74-83? I just bought a 1980 Hunter 30 minus the stove. The Hunter tech says the Origo 6000, however, the 6000 comes with an oven. I do not have a place for an oven, just a hole in the countertop for a drop in stove. I'm aware of the shortcomings of an alcohol stove, but I have a desire to restore this boat to "stock." Any help, please?
Jim2
Kenyon alcohol
My 81 was equipped with a Kenyon alcohol stove. There is one for sale on Ebay. Check Ebay item # 6516120644.
Dec 2, 1999
15,184
No one cares about STOCK!
Tony: No one cares about STOCK when it comes to these stoves. Do yourself a favor an look at an Origo alcohol or maybe better yet, think about a propane setup.
TONY A
Mar 7, 2005
30
Tony
I am leaning toward an Origo 4100, which I think will fit right in, and serve my intended use. However if I can replace the stove with original equipment I'd rather do that.
David lucas
Safety!!!
Be very cautious of wanting to replace the original alcohol stove. These have proven to be very dangerous with bad flare up. Instead look at some of the new Origo non pressurized as you have said. I would highly caution against pressurized, just from personal experience. My wife vowed she would not touch the original stove in our hunter until it was replaced with new. Dave&Jenn
A
Andrej Berlings
Origo stove.
Tony ORIGO is the way to go.Way safer than original Kenyon ,alcahol fire is not visible untill surounding area is on fire and any spilled alcahol will spread through holes in bottom of stove and ignite in the area bellow the stove.Origo stove can be filled safely in the sink.As for Propane it is heavier than air if you have aleak it will settle in the bilge waiting to go KABOMMM.Think about it.
Jim
Make the upgrade
I had a H-30 1981 with the Kenyon pressureized alcohol combination electric stove. I now have an Origo with a oven in my H-31. Love the Origo, safe simple, efficient, and it cooks better. The oven is a little slow to heat up.
TONY A
Mar 7, 2005
30
origo
I went with the Origo 4100 CB stove. Thank you all for your input! P.S. Anybody need the gimbled rack for the old stove?
