Jim S
I'm reviving my hunter 30 sailboat after a 15 year dry-dock. (having kids really changes the priorities).Almost got the diesel running this weekend but I have a rotted lube oil pipe going across the top of the block/crankcase. Ordered a new one from Torrensen/marine diesels direct but I don't have positive confirmation on the engine model.The operators manual is for both Yanmar YSE8 & YSE12. I'm pretty sure it's the 12 and I ordered the pipe to fit the 12, can anyone confirm?Also, I broke the brass shaft of the cockpit throttle lever. I think it would probably be difficult to find this specific part so I'm thinking of buying an entire throttle and gearshift lever assembly. Anyone have any thoughts on this? Should I go for the whole assembly? Where might I track down the throttle lever shaft if not? Where might I find/ order/ buy a new throttle and gear shift assy? I figure I'll probably have to go for new cables as well and maybe the linkage parts that hitch the cable to the Yanmars fuel pump/injector.
