Hunter 29.5 Wheel Brake?
Aug 7, 2026
1
Hunter 29.5 Mount Hope Bay
Purchased a 1997 Hunter 29.5 last month. Wondering if anyone has installed a wheel brake? I know you can add an Edson side brake to a traditional shaped pedestal, but I'm scratching my head on what to do here.
I know people are going to suggest adding an autopilot instead, but at this time that's not an investment I'm looking to do. Really I want to be able to grab a mooring single handed without having the wheel/rudder swing out in either direction and so far it's been a bit of a struggle.
Thanks in advance!
Likes: Brian M H23
Hunter 30_88-94 Ipswich, Ma MA
Ditto on the bungee. If you wrap it around the binnacle it’ll works fine. We have an Edson Folding Wheel and always secure it with a bungee after sailing.
Just my opinion but using an auto pilot for a wheel brake probably isn’t a good idea.
Why not? I had an ST3000 older 1986 external belt drive but with newer control head, i.e., same motor. If engaged and in Standby, pushing the +1 or +10 buttons would slowly move the wheel but kept it locked when the motor clutch was engaged. It's just like using the autopilot.
I do not know personally but I wouldn't be surprised if the ST4000 wheel mounted units worked similarly, because they just moved the belt to a different place.
When my control head gave up the ghost halfway through our 1,650 nm trip from SF to BC outside Newport, Oregon, we hand steered for a few days until I "discovered" that using the autopilot was a lot easier than hand steering. Even without the control head, I engaged the clutch at the motor and just bumped the wheel as necessary. We DID have a wheel brake, but knowing how it works on my Edson binnacle, I was disinclined to use it for steering. Not something I wanted to wear out.
Sep 24, 2018
4,821
Catalina 30 MKIII Chicago
The brake isn't all that powerful. Not worth the effort or expense in my opinion. I'm with those above that say use a bungee. It's more effective
Oct 3, 2006
1,041
Hunter 29.5 Delaware city
I have an old, nonfunctional raymarine belt drive autopilot in my 29.5, but the engaged belt drive and motor is a perfect wheel brake
