Fishing Line To Remove Old Portlight
To add to MikeH's good advice, Hunter told me to string a 3-foot length of 60# test fishing line through the caulk from the outside into the inside. Then, with 2 people (one on outside, one on inside), pull the fishing line tight and pull it around the window perimeter. The fishing line will cut through the old caulk. I haven't tried this yet, but plan on it in a couple of weeks. Hunter advises using Dow Corning 795 for caulk. In the archives, some folks advise using Lexan (polycarbonate) instead of plexiglass (acetate). Comments from others will be useful. BrianW
