Dave
I have a 1991 Hunter 28. I have a problem handling my boat in tight quarters because the rudder doesn't seem to 'swing' far enough from side to side. When the wheel is turned as far as it can go the rudder is only about 45 - 50 degrees off center, the stops prevent it from turning any further.Is this normal for this model? Is there an adjustment that I can make to allow the rudder to swing more?I have seen other boats where the rudder can move almmost 90 degrees off center and it seems that mine should do about the same.
