Hunter 28.5 scuppers venting smoke?
Trevor
When running my 28.5ft Hunters 15hp Yanmar diesel I have smoke blowing back up through the cockpit scuppers.
Brezo
Aug 8, 2005
16
Hunter 31_83-87 Portland, OR
I sometimes see a little when starting cold
With my H31 I will see some of the black smoke backup through the cockpit scuppers when I am starting the engine on a a really cold morning. I am betting your engine exhaust exits fairly close to the scupper drain. Of course I dont think you should get lots of black smoke all the time. Maybe when you start a cold engine or when you go full throttle.
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
Used to happen...
on my '87 model 28.5 when cold or had not been started in awhile. The smoke was coming from the exhaust under the transom and then back up the scupper drains. No big deal.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Is the problem...
... that you have "smoke" or where the "smoke" is going? You shouldn't have any smoke at all after the initial start and warmup of the engine. If you do, then something is wrong with the condition of your engine. If you really mean engine "fumes" are coming back at you when going downwind under power, there probably is not much you can do about that. As you know, the engine exhaust on the H28.5 is right next to the starboard scupper, yet I think the scupper exit is pretty close to or under water when the boat is underway. While I have smelled diesel fumes when going downwind under power now and then, I don't think they are coming up the cockpit scuppers, but rather just normal engine blowback from the exhaust.
Benny
Black smoke!
Your engine is suffering from overfueling. Fouled prop, bad fuel or dirty filters are causing the black smoke. These are the usual causes; if everything checks OK verify the timing on the fuel injection pump. No big deal that the smoke is coming back up through the scuppers.
Jun 7, 2004
944
Birch Bay Washington
Usual cause in my experience
is the d*mn exhaust elbow. Check the archives or make a Home Depot model like I did.
