Hunter 27 Bimini
Jul 21, 2014
61
Hunter 27 Cherubini Lanoka Harbor
Ok. Need some measurements. I have a 1979 27 with a tiller.
What width bimini is ideal?
Feb 17, 2006
5,274
Since SBO is a combined site of the most popular boats, you might just find a bimini for your H27 in the SBO store. Did you try looking there?
braol
Apr 16, 2014
348
Hunter 27 Rebel 16 Great Lakes Naval Base, IL
You'll have to measure from just inside the toerail on one side to the other.
braol
Apr 16, 2014
348
I'm doing a bimini later this season and plan on installing aluminim U-plates/U-channel as mounts just inside of the toe rails on either side. I'll mount the tubular aluminum frame to these with pins or bolts. I don't think there's any specific measurement for this as it depends on where you place your mounts. It's more of a custom job.
PS I had thought of using the toerail itself as a mounting point for the bimini frame. I figured I could make a 'sandwich' of aluminum plate-toerail-aluminum plate and just drill holes in the plate and align them with the existing holes in the toerail. A bolt or pin could then pass through here as the mount for the base of the bimini frame. My brother has a nice folding top on his pontoon boat I'm using as a model for my own bimini. It's just a tubular aluminum frame that folds and locks with a sunbrella fabric top. It shouldn't be too difficult to mimic.
Sep 12, 2011
88
Hunter 27 Annapolis
Yes, I am tempted to get a universal fit one from west marine. (According to my measurements). Only I (most of us) have a split back stay which I have to stitch velcro pockets into. This is leading me to believe that I should have a canvas worker do it or something. Just kinda spendy. I'd love a dodger over a bimini but that would be way too expensive, also I'm worried about the main sheet configuration with my mid-boom sheeting on the 1980 H27.
I was actually thinking of mounting it on the stern pulpit. Only I fear it will make the pulpit weak in a blow even with the bimini furled up.
Apr 16, 2015
4
hunter 27 Elizabeth City
I was actually thinking of mounting it on the stern pulpit. Only I fear it will make the pulpit weak in a blow even with the bimini furled up.[/QUOTE]
I have a 1981 Hunter 27 with Bimini mounted on one round aluminum tube mount attached to each side of chrome stern bottom rail about 8" from the front of the pulpit. I just bought boat in the winter. I suspect the three leaf frame stays up by lines attached somewhere? I can give you measurements of the cover however it seems to me you'd need to size cover by whatever frame you purchase or fabricate.
