DON'T REMOVE BOW PULPIT!!!
I'm going to have to respectfully disagree with JC on removing the bow pulpit altogether. The very last thing that I want to do is fall off the boat!!!Just because you have a furler doesn't mean you won't have to go forward. What do you do when the furler jams??? (It will.) If you have a spinnaker, you'll go forward often. One also has to go forward to anchor and to dock and to moor and you have to do that in all kinds of conditions, good and bad. The bow pulpit gives you a solid place to hang on when the seas and weather are rough. Without it, all you have are the leftover lifelines and the jib & headstay for handholds -- these don't provide the same kind of security and safety as 1" SS tubing.Also, I guess ABYC standards are always open to interpretation, but paragraph H-41.6.1 states:"The outside periphery of weather decks, normally intended to be occupied while the boat is underway, shall be equipped with one or more of the following;a. life rails, deck rails, or life lines,b. handhold devices or grab rails,c. stern rails, bow rails, ord. coaming, gunwale, bulwark, or enclosure of at least 24 inches (610mm) above the deck."I would argue that the foredeck qualifies as a place that is "intended to be occupied while the boat is underway."H-41.6.3.1 further emphasizes the height requirement: "The minimum height of a life or deck rail or life line shall be 24 inches (610mm) above the deck."Personally, I'd rather sail ON a roly-poly boat than fall OFF a stable one.
