Hunter 260 - where can I find the HIN
3
Hunter 260 Fort Lauderdale
Hello all,
I've tried searching this and other forums and I read everywhere that the Hull Id Nmbr should be in the transom, starboard side, etc....I have a Hunter 260 from 2003 and I do have the title so I know the HIN, but where can I find it in the boat? I'm expecting like a little plaque with the same number as the title....and can;t find it anywhere :-(
Thank you for your help!
Jorge
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Outside starboard transom is where they all usually are.....closer to the deck
Oct 6, 2007
1,172
Hunter H30 1982 Chicago IL
It's hidden in plain sight
It's not an attached plaque. The HIN is discreetly embossed into the hull. Where RAD says.
Oct 22, 2005
257
Hunter 44DS Redondo Beach, CA
In your case it won't be on the transom, it will be near the stern on the Starboard side, about the same level as the rail.
Beneteau 323 Annapolis MD
Well, since no other 260 owner has chimed in with an authoritative post, you could always call a Hunter dealer for the location.:doh:
Dec 2, 2003
766
Hunter 260 winnipeg, Manitoba
Hin 260
You will find the HIN just forward of the forward stanchion of the pushpit on the starboard side. If you have the hunter 260 decal it is above and aft of the "H" Around the turn in the rubrail. (it is a bit hard to locate as it is just a depression in the gelcoat.)
Now THAT'S what I'm talkin about !:dance:
Mar 26, 2011
3
Thank you for your help everybody!
I am still unable to find it but at this point I wonder if there issomething fishy about it :(
I am heading to the dmv for inspection tomorrow.the title I have has a clean number but I can't match it with the boat...i hope everything is ok.
Thank you everybody!!
Jorge
