W
wayne lentz
I took delivery of a 2001 hunter 260 with wheel steering this week. The dealer delivered and set the boat up. On my first attempt to take the boat out I realized that it was extemely difficult if not impossible to get to and adjust the main sheet attached to the cockpit deck directly in front of the wheel pedestal. On my second attempt to take the boat out (same day) I switched the main sheet apparatus around putting the cleated block up near the boom. This was much easier to reach and make adjustments until I got into some 15-20 knot winds. At this time the boat heeled quite a bit and I was unable to uncleat the main sheet. I had to turn into the wind, lower the sails, calm my wife down,and motor in. After discussing this problem with the "old salts" at the docks they came up with the idea of adding a length of line from the boom lowering the main sheet block from the boom to waist high level. This seems to be a little easier to maipulate the main sheet but I would like to know if there is anyone that has experienced the same problem or if there is another way of setting up the main sheet to be compatable with wheel steering?
