Hunter 260 Genoa Blocks in Wrong Place ???
81
Hunter 270 Ottawa
I had a 170% Genoa on my 2002 Hunter 270 (treat as a 260 model). I have just replaced it with a new 110% Genoa. With the standard Genoa blocks, the Genoa sheets pulls straight down on the leech of the sail, not on a 45 degree angle. A friend recommended I install small Genoa tracks to correct this situation. If I install the tracks should I move them towards the midline of the boat or should I stay on the same line as the standard Genoa block ???
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
deck block looks right
If you look at the drawing of the H260 and you draw a line from the deck block through the jib clew it lands about halfway between the head and tack as it should. That is with the stock 110%.
-na -NA Anywhere USA
The blocks for the genoa 170 were added on privately and not by the manufacturer. I found that a 170 was overkill for the 270. You are correct that it is based on a 260 but with a keel vs. water ballast. There were a few minor differences but it is built off a 260 chassis as I would say. I introduced that boat for Hunter along with the 260.
