Hunter 26 Steering Config
Aug 23, 2011
20
Hunter 26 Petawawa
Hi Everyone,
I hope everybody is doing well and staying healthy.
I have a 94 Hunter 26 that had a wheel installed with the push-pull system, I find that while heading downwind the pressure on the rudder and steering is REALLY heavy. I'd like to replace the push-pull with pull-pull but as I understand it after contacting Edson, the company that produced the linkage, rods and cables is no longer in business and edson's pull-pull setup will not work in a Hunter 26.
I was hoping one of you fine experienced sailors could provide an option to me to improve my system, or rig a pull-pull somehow. I am hoping I am not stuck with it as is until it fails and I have to reinstall the tiller setup.
Thanks in advance.
Sorry if this is a repeat post of something covered, I'm not really forum savvy.
-na -NA Anywhere USA
Advise in pvt message as to phone number, location of boat. Do you know where the boat originated? Probably one of mine.
Crazy dave
I will send a detailed messsage and then give you a call. Give me a couple days as I have work to do for my wife called honey doos
Oops. I should have read first. Can you take photos inside rear berth cabin ceiling, area behind rear berth area via access panels, wheel and transom where rudder is attached
Aug 23, 2011
20
Hunter 26 Petawawa
Sure, I took some for the edson folks. Sent you one of the keel via pm. Sorry about the blue tint on outside, still tarped up here. Unfortunately no pics of aft cabin, I can get some later tho if required.
20
Hunter 26 Petawawa
I've got a new boot, and regardless if I can do anything with the steerage, I'm going to reseat everything rudder related on the transom
Edson temp shut down to pandemic. Now I need photos of the push pull system not cable. What is seen is the system thru rear storage locker beneath which is an open locker to rudder hookup. I need to see photos of the base in rear berth, pedestal interior and photo of pedestal. The 260 was offered with a normal pedestalbcable system st my insistence with me getting away from push pull. 260:thumbsdown: Boat was a winner
Aug 23, 2011
20
Hunter 26 Petawawa
My mistake, I was there today and forgot. I got sidetracked by a soft spot I found on the hull, I will get some to you tomorrow for sure.
