Hunter 26 Replacement Mast
Terry
The marina that took down my mast last year bent it when they were taking it down. They unhooked the furling jib, lost control and it crashed into the back support denting it and putting a 5-degree bend in it. I can still sail her just fine but my main does not fill as it used to and am worried it will come crashing down due to the new weak spot.
Does anyone know where I can find a replacement mast for Hunter 26? I'm OK with a used one (so long as it's in good shape). I'm in Texas so I would rather find one close by. Let me know if you have any ideas.
Thanks,
TK
Jun 2, 2004
3,670
Last Time I Looked
US Spars had two that were slightly damaged and marked down quite a bit
http://usspars.com/
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
US Spar
I replaced my mast of my 1994 H26 with a US Spar mast. It was damaged by Hurricane Ivan even when it was on the trailer on the hard. BrianW
tkahler
Thank You All!
Thank you all for your help. I really appreciate it. I got a good price from US Spars. A lot cheaper than I expected. Will be fun to sail with a straight mast!!!
TK
