Hunter 26.5 sheet and halyard specs
16
Does anyone know what the lengths and diameters are for the sheets and halyards on my 26.5? The boat did not have any when I bought it. Thanks.
Dec 2, 1999
15,184
Brucer:
Check out the store website. They have very good prices on line with or without hardware. They already have the measurements for your boat too.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
When you buy your new halyards be sure to use long eye splices. This will allow you to remove and/or change shackles without having to cut the line. You could also consider having the splice at both ends to allow you to reverse the line as chafe starts to develop.
Sep 19, 2010
48
Beneteau 41 Deltaville, VA
Mine are 80 ft long for the main halyard, and 77 ft each for the jib and spinnaker. I previously used 3/8 inch diameter but changed this year to 5/16 inch and the sheet stoppers still grab well (your hardware might be different, mine are Spinlock.) For the mainsheet I'm using 3/8 inch diameter by 54 ft long. I can't locate my jibsheet info right now.
