Hunter 25
1
Hunter 25 Rockwall, Tx.
I have a 1975 hunter 25 sailboat, and I can't determine the exact weight of the boat. I'm looking to put together a trailer for the boat. Does anyone know what the weight of this boat would be?
Thanks for your help.
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
According to the boat info tab on this site, it weighs in between 4400 and 4600 pounds depending on what keel you have. According to the info over at sailboatdata.com, it weighs 3850 pounds. If it were me, I would design the trailer for the heaviest weight listed just to be on the safe side.
Cheers,
Brad
May 24, 2004
7,202
CC 30 South Florida
Cherubinis were built kind of heavy so the 4,600 lbs of displacement for the short keel model sounds very reasonable. I would add another 500# for all the boat stuff that will find its way aboard.
-na -NA Anywhere USA
When designing a sailboat trailer, like everone said, you need to figure the wieght of the boat with the specific gear on board. You will need to figure for safety a minimum of additional 10% weight. For example a 4000 lb boat figure 4400. Depending on the keel, you will need to have high supports. You can elect to get screw pads or bunk board style. I prefer the bunk boards with four support stands each side for the bunk boards. Make sure the keel tray is big and stout. You will need brakes on both tandem axles which in many states are required. I prefer disc surge brakes as salt water in particular is not good on electric.
On the bunk board style, you can get the plastic runners to move the boat easier onto the trailer but make sure that you strap the boat down in the back so the strap is foward. If there is no bow stand on the trailer, then strap the bow down with the strap backwards. With the straps put a few twists in them to keep them from slapping and when you go 20 miles, pull over and resecure everything.
but above all, do not convert an old power boat trailer over. Most generally were not built for sailboats and I have seen many fail.
If you are thinking of buying a new trailer for a sailboat, then the most experienced and knowledgable person is Ron frisosky who has designed many for many manufactured sialboats to include hunter, macgregor, catalina, precision, seaward, etc. for Road King Trailers Under Sailors trailers. Cell phone is 941-914-3890. Normnally I do not do that but so many claim to know sailboat trailers and they do not.
Good luck
dave condon
