Skip Howe
Had to remove the rudder as it had a crack in the leading edge, which was discovered while cleaning the bottom. When the rudder and shaft were removed, the shaft was found to have a plastic/teflon sleeve around it, which evidently assists the rotation of the shaft in the fiberglass shaft recepticle in the boat. Now, anyone know where I can get such an animal? It's quite a thin sheet, and probably have to be sub'd.Thanks.Skip
