Stuart Cook
I’m looking to purchase a 25.5 and have found one that appears in good shape except for a possible problem in the keel area. This boat has the shoal draft keel. Towards the rear of the keel in an area about an inch and a half down from the hull there is a rusty crack line running about one foot along the keel. Inside the boat I can see two large Stainless Steel bolts securing the keel at about the mid point. They are clean with no rust. The single Stainless Steel bolt securing the rear of the keel has a lot of rust marks on it that coincides with the rust in the same area of the keel on the outside. Obviously the stainless steel bolts are not rusting - it’s the rust from the keel getting through and onto the bolts.Is this a big problem? Is there some kind of seal between the keel and the hull like a rubber gasket or goop? Does it mean the keel is loose? What’s the best plan of action? Anyone have any idea?Thanks, STU
