Sir, you have a light with two light bullbs with a seperator plate in between the two bulbs with three wires coming out. That style light was used primarily on many smaller Hunter trailerables. Two wires are hot or positive and one for ground or negative on a DC system or battery sysem only. The front light only is to satisfy a white illuniated steaming light at night while under power. I always had mine on when sailing too. With the two lights illuminated is for the required anchoring light. If you are on a lake, that anchoring light well was a joke as most bass fishermen look straight and not up which is why I told my customers to get a led rechargable light to hang from the boom while anchored at night for any lake boat out there.
First a dumb question. Is the deck light connector has two, three or four holes which can also be determined by the male counterpart plug in??? The nest quesion is the wiring to the deck light connector from the panel two or three wire???? You have already told me the wiring in the mast was two wire.
Send me an email with that information and then I can tell you what to do. rmail to
davecondon@mindspring.com and then I will inform you what to do. Heck include your phone number as I hate to type. I will advise the forum what I willl tell you. I introduced this boat for Hunter.
crazy dave condon
