Hunter 240 2001 identification number
rkb
Aug 26, 2012
1
Hunter 240 Lake Alatoona
i am looking to buy a hunter 240 2001
i don't see a fed registration number
is there a hidden identification number somewhere?
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
It is actually easy to see. Stern, right side, outboard from the motor mound, just under the hull/deck joint.
-na -NA Anywhere USA
it is also located under the companionway if you will lift up it all the way and you will see it in the water channel.
