First off, I'd like to say hello to everyone and introduce myself as this is my first post here. The wife and I just purchased a 1985 Hunter 23 w/swing-wing keel that is in great shape, but had sat idle for quite some time and needs a bit of TLC to get her back into shape. For a couple of different reasons, we actually downsized from our previous Hunter 27, but it was mostly so we could trailer the boat to where we wanted to sail instead of driving to the boat to sail. Being in North Central Florida, we have our choice of either coast, but will likely spend most of our time on the east coast around the St. Augustine area.
Like I said, the H23 had been sitting idle for a while, so I'm slowly going through everything that needs to be looked at and fixing/replacing as I go along. Hope to have her ready to sail soon, as summer is fast approaching, and I would like to get her back to as close to original condition as possible. I'm sure that having access to this forum and other H23 owners will be a great resource in achieving that goal!
One problem I have is the companionway hatch/door. As I understand it, the forward part of the hatch (fiberglass section) is hinged, and there is a (lexan?) slider behind that slides under the forward portion. The previous owner took the slider portion (which he says was broken anyway) and cut it into an appropriate "V" shape to use as the companionway door that was missing, and then fashioned a plywood 'slider' to replace the original. Needless to say, it's less than optimal and I would like to get it back to original.
That said, can anyone provide a picture and perhaps diminsions of the various parts of the hatch and maybe explain how it operates? I'd like to fabricate a duplicate of the sliding portion, and I believe I have the original teak that was on it. Also, when the slider is pushed forward, does it somehow secure itself to the fixed/hinged part so it lifts up along with it? It doesn't make sense if you could hinge the fiberglass part up but the slider stays in place.. or maybe you are just supposed to remove it completely and stow it like you would the door portion? And along those lines, how are you supposed to keep the hinged portion up? Tie it off somehow to the mast, or perhaps it had an adjustable lift at one time? Having never seen what the original configuration looks like, I'm sort of at a loss..
Thanks for any input!
Cheers,
Brad
Cheers,
Brad
